How to ping when connected with IPSEC client ?
I use an ATP200. I have configured a VPN connection for a Zywall IPSEC VPN Client.
The tunnel is opened but it's impossible to use RDS (Terminal server), neither to ping the server .
I've tried to create some rules in :
Network -> routing
and in Network -> NAT
and also in Security Policy -> Policy Control
But nothing works.
Anyone could help me please ?
Regards
Herve
Hi @Herve13 ,
Welcome to Zyxel Community. ?
There is no need to create NAT rule and routing in this scenario, once the VPN tunnel is up, the traffic can be routed to internal Lan.
As for security policy, the traffic hits the rule from IPsec_VPN to any. Make sure the rule is allow in security policy.
“CONFIGURATION > Security Policy > Policy control > IPSec_VPN_Outgoing”
Thank you for your answer.
This rule was created automatically. But it seems not to be enough.
Another idea ?
Hi @Herve13 ,
Can you send me your configuration file via private message?
Let me have a quick check on your settings.
Hi @Zyxel_Cooldia ,
I could fix the problem. As you said there was no rule to add, I tried to find a problem with the VPN configuration. Even if the tunnel was opened it was not working. So I tried to create it in another way and it's OK now, thank you very much for your help !
Hervé
Hi @Herve13
Good to hear that you found the solution yourself. ?
Feel free to let us know if you encounter any problems in future.
- 245 Nebula Ideas
- 6.9K Security
- 813 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 543 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 125 Security Highlight
