NWA5121-NI Lost Configuration each Reboot
Dear Zyxel Friend,
I have AP Zyxel NWA5121-NI, I use it standalone (not managed with cotroller), the problem of this AP is each reboot it back to initial configuration.
how I can deal with this problem !!! that really strange, I alway reconfigure my AP ?
Firmware Version inside :
Firmware Version : V5.10(AAID.2) / V2.2 / 2017-10-02 04:31:02
Regards.
Hi @Nenday
Welcome to Zyxel forum community!
Do you mean every time you reboot NWA5121-NI, then you see your new reconfigured SSID name back to the original Zyxel SSID or ?
Please help us to collect the configuration files(startup-config.conf and startup-config-bad.conf) with normal reconfigured and after reboot AP as below screenshot.
Thanks!
Hi Panda,
thank you for your reply,
exactly that, every time I reboot the Zyxel it back to Zyxel SSID and lot all config I make.
that all file I found on :
here attached the actual Config File (I change the extension to .txt to be able to add here) please change back to .conf if you wanna check it.
Regards.
Hi @Nenday
Thanks for your information. I will PM/mail to you for checking more details.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
