USG 40 Pb with asymetric routing
ZeroFX
ZeroFX Posts: 7 image  Freshman Member
edited April 2021 in Security
I need to replace a Juniper Firewall and i test with a USG40.
My USG 40 is directly connected to internet.
I have 2 statics routes :
10.0.0.0/8 to 10.59.120.2
0.0.0.0 to 10.59.120.1
But i can access to internet but not in all network 10.0.0.8/24
With old Juniper it's ok, i have disable in global option sequence-number checking and SYN-flag check, and in the rule LAN to WAN i have enable sequence-number check and SYN-flag check.
Can you help me.
Thanks!
«1
  • zyman2008
    zyman2008 Posts: 246 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    Hi @ZeroFX,
    Enable "Allow Asymmetrical Route" option in Policy Control page.
    It will bypass the TCP state check.
  • jonatan
    jonatan Posts: 200 image  Master Member
    5 Answers First Comment Friend Collector Eighth Anniversary
    Use ip aliases, if the option is enabled Allow Asymmetrical Route lowers the level of security in local network - firewall does not process traffic on the areas: LAN-LAN, WAN to WAN, DMZ to DMZ, WLAN-WLAN, VPN VPN .
  • ZeroFX
    hi,
    I have never use ip alias, can you explain me it please for my case.
    Thanks you
  • jonatan
    Add the local interface of the Zyxel (10.59.120.1/24) to another virtual interface (e.g. 10.0.0.1/8) , which will serve as a gateway for your Network 2 and prescribe this gateway on the clients Neetwork2, for distribution to the Internet.
    PeterUK Posts: 4,552 image  Guru Member
    edited September 2019
    To me this seems like a network overlap with 10. (but maybe its fine) I did some testing and you can get the network working if you change 10.59.120.2/24 to 192.168.120.2/24 and 10.59.120.1/24 to 192.168.120.1/24
    Switch L3 same VLAN Interface
    10.0.0.1/8
    192.168.120.2/24
    USG LAN1
    192.168.120.1/24
    USG routing
    incoming LAN1 Source 10.0.0.0/8 destination any next hop WAN SNAT outgoing-interface
    and do the static routes
    USG 10.0.0.0/8 to 192.168.120.2
    Switch L3 0.0.0.0/0 to 192.168.120.1
    All worked without needing Allow Asymmetrical Route or virtual interface...but maybe I'm missing something?
    Edit access to 10. from 192.168.120.0 so as @jonatan said you need the virtual interface on LAN1 for 10. you then need a firewall rule from LAN1 to LAN1
  • ZeroFX
    Thanks to jonatan and PeterUK, but i can't change the network IP, GW IP…
    I need just replace the Juniper FW, why it's simple with a Juniper and why a ZyXEL FW can't do this in the same IP topology?
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,590 image  Zyxel Employee
    Hi @ZeroFX
    Welcome to Zyxel Community. ?
    Can you post the result of CLI “show ip route-settings” on USG?
    Static route:
    Router> show ip route-settings
  • ZeroFX
    Route          Netmask        Nexthop        Metric
    10.0.0.0       255.0.0.0      10.59.120.2    0
    0.0.0.0        0.0.0.0        178.211.X.X      0    it's my WAN IP GW
  • Zyxel_Cooldia
    Hi @ZeroFX
    There is no need to add static route 0.0.0.0/0 178.211.X.X for wan gateway.
    Please delete this routing entry and try it again.
  • ZeroFX
    Thanks Zyxel_Cooldia,
    I need enable "Allow Asymmetrical Route" ?
