USG 40 Pb with asymetric routing
I need to replace a Juniper Firewall and i test with a USG40.
My USG 40 is directly connected to internet.
I have 2 statics routes :
10.0.0.0/8 to 10.59.120.2
0.0.0.0 to 10.59.120.1
But i can access to internet but not in all network 10.0.0.8/24
With old Juniper it's ok, i have disable in global option sequence-number checking and SYN-flag check, and in the rule LAN to WAN i have enable sequence-number check and SYN-flag check.
Can you help me.
Thanks!
Hi @ZeroFX,
Enable "Allow Asymmetrical Route" option in Policy Control page.
It will bypass the TCP state check.
Use ip aliases, if the option is enabled Allow Asymmetrical Route lowers the level of security in local network - firewall does not process traffic on the areas: LAN-LAN, WAN to WAN, DMZ to DMZ, WLAN-WLAN, VPN VPN .
hi,
I have never use ip alias, can you explain me it please for my case.
Thanks you
Add the local interface of the Zyxel (10.59.120.1/24) to another virtual interface (e.g. 10.0.0.1/8) , which will serve as a gateway for your Network 2 and prescribe this gateway on the clients Neetwork2, for distribution to the Internet.
To me this seems like a network overlap with 10. (but maybe its fine) I did some testing and you can get the network working if you change 10.59.120.2/24 to 192.168.120.2/24 and 10.59.120.1/24 to 192.168.120.1/24
Switch L3 same VLAN Interface
10.0.0.1/8
192.168.120.2/24
USG LAN1
192.168.120.1/24
USG routing
incoming LAN1 Source 10.0.0.0/8 destination any next hop WAN SNAT outgoing-interface
and do the static routes
USG 10.0.0.0/8 to 192.168.120.2
Switch L3 0.0.0.0/0 to 192.168.120.1
All worked without needing Allow Asymmetrical Route or virtual interface...but maybe I'm missing something?
Edit access to 10. from 192.168.120.0 so as @jonatan said you need the virtual interface on LAN1 for 10. you then need a firewall rule from LAN1 to LAN1
Thanks to jonatan and PeterUK, but i can't change the network IP, GW IP…
I need just replace the Juniper FW, why it's simple with a Juniper and why a ZyXEL FW can't do this in the same IP topology?
Hi @ZeroFX
Welcome to Zyxel Community. ?
Can you post the result of CLI “show ip route-settings” on USG?
Static route:
Router> show ip route-settings
Route Netmask Nexthop Metric
10.0.0.0 255.0.0.0 10.59.120.2 0
0.0.0.0 0.0.0.0 178.211.X.X 0 it's my WAN IP GW
Hi @ZeroFX
There is no need to add static route 0.0.0.0/0 178.211.X.X for wan gateway.
Please delete this routing entry and try it again.
Thanks Zyxel_Cooldia,
I need enable "Allow Asymmetrical Route" ?
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 213 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
