USG 40 Pb with asymetric routing
2»
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,568 image  Zyxel Employee
    @ZeroFX , i test it in local lab, no need to enable "Allow Asymmetrical Route" in this scenario.
  • ZeroFX
    ZeroFX Posts: 7 image  Freshman Member
    Zyxel_Cooldia
    i test now, my pc have ip adress 10.59.120.16/24
    my PC ping 10.59.120.2 and 10.59.120.1 and 8.8.8.8 but not machines behin my L3 switch for exemple 10.X.X.X
    PeterUK Posts: 4,264 image  Guru Member
    Did you add the virtual interface on the interface that has 10.59.120.1/24 on the USG with 10.0.0.0/255.0.0.0?
  • Zyxel_Cooldia
    Hi @ZeroFX
    Can you see the packets on USG40 Lan interface if you ping from a host which behind layer 3 switch ?
    Packet capture CLI:
    Router> packet-trace interface lanX extension-filter icmp
  • ZeroFX
    Hi @ZeroFX
    09:44:16.397169 IP 10.59.102.44 > 10.59.120.1: icmp: echo request
    jonatan PeterUK
    I add lan2:1 10.59.120.3 255.0.0.0 now all it's ok
    THX
