USG 40 Pb with asymetric routing
@ZeroFX , i test it in local lab, no need to enable "Allow Asymmetrical Route" in this scenario.
i test now, my pc have ip adress 10.59.120.16/24
my PC ping 10.59.120.2 and 10.59.120.1 and 8.8.8.8 but not machines behin my L3 switch for exemple 10.X.X.X
Did you add the virtual interface on the interface that has 10.59.120.1/24 on the USG with 10.0.0.0/255.0.0.0?
Hi @ZeroFX
Can you see the packets on USG40 Lan interface if you ping from a host which behind layer 3 switch ?
Packet capture CLI:
Router> packet-trace interface lanX extension-filter icmp
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
