External certificate for SSL Inspection not work
this is my first question.
For my usg310 I have buyed and installed a external certificate following this guide:
ftp://ftp.zyxel.it/guide/usg/guide_next_gen_usg_firmware_4/next_gen_usg_ssl_import.pdf
I have configured it for 'SSL Inspection' but when I try to navigate i receive error "NET :: ERR_CERT_INVALID"
In the browser certificate info i view this alert: 'certificate invalid for the selected purpose'
When i have generated the Certificate Request i have this 'key usage':
After Import generated certificate:
Is my problem caused by this?
The problem is the 3rd Party SSL Certificate Authority, which generates the certificate without needed 'key usage'?
I found this in the knowledge base:
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015551&lang=EN
If I understand correctly, is not possible to configure an external certificate for ssl inspection!
So the guide I found is wrong?
any answers?
Hi @Briz
Welcome to Zyxel Community. ?
The KB is correct. The external certificate is type of an end-entity certificate which is a digitally-signed statement issued by a Certificate Authority.
In SSL inspection scenario, you cannot import “end-entity” certificate as a root CA.
Please use self-sign certificate for SSL inspection.
Hi @Zyxel_Cooldia,
thanks for your reply, now i use self-sign certificate for SSL inspection.
For clarity, I meant this as an incorrect guide:
on page 8 in "SSL Inspection" sets the external certificate buyed form 3rd Party SSL Certificate Authority
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
