USG 1900 DHCP POOL EXPORT problem
Hicabi_Yeniay
is there any way to get DHCP pool list as a TXT or csv files from the DHCP screen?
I don't know if there is any way to "export" the list as a file.
You can use the command on console/SSH to show the DHCP table and find a way to copy the list.
Router> show ip dhcp binding1 -
Hello Hicabi_Yeniay,
Here is the way to export the DHCP list from console, please check the following below.
Connect with device via SSH or telnet and Go to File>Log
Create the txt file and press save, all logs will be recorded on it.
Enter "Show ip dhcp binding" to list DCHP client.
The log will be saved after press Pause and Close it.
Result
Charlie
2
- 441 Beta Program
- 293 Service & License
