External certificate for SSL Inspection not work
Briz
Briz Posts: 20 image  Freshman Member
edited April 2021 in Security
this is my first question.
For my usg310 I have buyed and installed a external certificate following this guide:
ftp://ftp.zyxel.it/guide/usg/guide_next_gen_usg_firmware_4/next_gen_usg_ssl_import.pdf
I have configured it for 'SSL Inspection' but when I try to navigate i receive error "NET :: ERR_CERT_INVALID"
In the browser certificate info i view this alert: 'certificate invalid for the selected purpose'
When i have generated the Certificate Request i have this 'key usage':
After Import generated certificate:
Is my problem caused by this?
The problem is the 3rd Party SSL Certificate Authority, which generates the certificate without needed 'key usage'?
  • Briz
    I found this in the knowledge base:
    https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015551&lang=EN
    If I understand correctly, is not possible to configure an external certificate for ssl inspection!
    So the guide I found is wrong?
  • Briz
    any answers?
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,590 image  Zyxel Employee
    Hi @Briz
    Welcome to Zyxel Community. ?
    The KB is correct. The external certificate is type of an end-entity certificate which is a digitally-signed statement issued by a Certificate Authority.
    In SSL inspection scenario, you cannot import “end-entity” certificate as a root CA.
    Please use self-sign certificate for SSL inspection.
  • Briz
    Hi @Zyxel_Cooldia,
    thanks for your reply, now i use self-sign certificate for SSL inspection.
    For clarity, I meant this as an incorrect guide:
    on page 8 in "SSL Inspection" sets the external certificate buyed form 3rd Party SSL Certificate Authority
  • Zyxel_Cooldia
    Hi @Briz ,
    Thank you for highlighting the error in our documentation.
    We will correct this guide.
