Only one VNC socket works: 5901
I don't understand why only one VNC socket works for my Linux server. Before I used the USG40 I tested several connections (sockets 5901-5904) and they worked fine. I connected the USG in the following "circuit": Fiber(AT&T), Modem(AT&T), Router (AT&T) with Port forwarding IP to USG40. On USG40 P2 WiFi, P3 Linux Server, P4 PC, P5 NAS (all four on LAN1). It would seem to me your USG40 is stopping the traffic in all but 5901.
It looks like the only port open on my Linux box is 5901. This is odd because I:
[root@server userid]# firewall-cmd --zone=public --add-port=5900-5910/tcp --permanent
success
[root@server userid]# firewall-cmd --list-all
public(active)
ports: 5901/tcp
URGH!!!!
Hi @paulmmluap
Can you see VNC packets on Lan interface if you connect VNC from Internet?
For port mapping settings, you also need to create a firewall rule to allow VNC traffic from wan to lan.
Packet capture CLI:
Router> packet-trace interface lanx extension-filter port xxxx
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
