Change from USG110 to ATP800
Hello, I will soon change a USG110 for an ATP800.
The client has grown and needs more security, the problem is the amount of data of the USG110, VPN, SSL ect.
Can I convert the USG110 database for the ATP800?
Or would I have to configure the ATP800 from the beginning?
Gracias.
Hi @Pedroj ,
You cannot convert the USG110 configuration file to ATP800. You need to set up manually from the beginning.
Hola, ok gracias.
- 603 USG FLEX H Series
- 481 News and Release
