GEO-ip database update problem.
Niviteka
Niviteka Posts: 17  Freshman Member
edited April 2021 in Security
We have 2 Zywall 310 devices. Both have a CF license activated. Firmware versions are the same.
In this case, one device updates the GEO-IP data normally, while the other does not update.
When updating manually, the following error appears.
Geo-IP country database version 20190904 download has failed
Auto-update also does not work.
In this case, the IDP/AppPatrol signatures are updated normally on both devices.
Best Answers
  • Niviteka
    THANKS- Problem was in limited ISP connection.
  • jasailafan
    jasailafan Posts: 193  Master Member
    I got the same issue on ZyWALL 110 and talked with zyxel support last week.
    The zyxel Support told me it is confirmed as a bug on the Geo IP update server and the issue is planned to be fixed in November.
    So let's wait for the fix.?
  • jasailafan
    Niviteka,
    Zyxel support just told me the issue on the Geo IP update server is fixed.
    The database is able to be updated to the latest version successfully.
    Try to update the database on your zywall310.
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    edited September 2019
    Hi @Niviteka ,
    Welcome to Zyxel Community. ?
    Feel free to let us know if it is still fail to get latest update.
  • Niviteka
    Hi!
    Unfortunately, the situation has not improved.
    There is still an error on 1 device.
  • Niviteka
    The problem is only with updating the GEO-IP database.
    In this case, IDP/APP Patrol updates occur normally.
  • Niviteka
