Network Internal Loop
Hello Guys,
I hope someone can help me with my Problem.
A customer of us got a new connection with SIP-Trunking. Everything is working fine till we connect the Lancom to the Switch, like shown above. It is needed for the telephone system to communicate.
As soon as we connect it, the Internet goes down and enters some kind of loop.
Is it possible that the WAN Port in our Zyxel is missconfigured?
If yes, is there a sample-conf to setup the WAN Port for Ethernet?
Greetings.
Can you change the Lancom 883+ subnet (and accordingly, USG115 Wan Port subnet)?
Try to use something different just like 192.168.250.0/24 subnet.
Long story short: use the same subnet on two different interfaces (not ports) AFAIK is not possible.
2
2 -
I will try it out, thanks :)
Consider to split the switch into 2 vlans, for avoiding dual DHCP servers.
We already did 2 vlans, but for the guest wifi.The DHCP server is disabled on the lancom, since normal clients obtain the IP through the Zyxel USG DHCP.0
Thanks for the explanation. Have a lot of fun.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 489 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
