ZW USG 1100 433AAPK0ITS-WK35-r89892 don't work Web & SSH
Hello again.
After update on new FW, given for resolve bug with ipsec https://businessforum.zyxel.com/discussion/2893/ipsec-via-main-gw-stops-work-found-old-outbound-spi-error-in-debug-log/p1, ssh and web-gui don't work!!! AGAIN!!!
login as: admin
Using keyboard-interactive authentication.
Password:
Unable to connect ZySH daemon
command function history:
0x1009e1d8 argc:4 args:show interface cellular
0x1002b0c0 argc:6 args:show logging entries priority alert
0x102e9ec0 argc:4 args:show firewall block_rules
0x102e9f30 argc:4 args:show firewall6 block_rules
0x10201348 argc:4 args:show ipv6 status
0x1000fbc0 argc:2 args:exit
0x1000fd38 argc:1 args:
0x1013ad78 argc:1 args:
0x103214d8 argc:4 args:connectivity-check ok vti5
0x103214d8 argc:4 args:connectivity-check ok vti15
0x1000f4b0 argc:1 args:
0x1000f998 argc:1 args:
sh: /etc/zyxel/ftp/tmp/zyshd_bt/2019-09-24-09-41-26_zyshd.dbg: Permission denied
/usr/sbin/gdb_parser_t.sh: line 41: /etc/zyxel/ftp/tmp/zyshd_bt/2019-09-24-09-41 -26_zyshd.dbg: Permission denied
/usr/sbin/gdb_parser_t.sh: line 51: /etc/zyxel/ftp/tmp/zyshd_bt/2019-09-24-09-41 -26_zyshd.dbg: Permission denied
Bad terminal type: "xterm". Will assume vt100.
Router>
GREAT WORK!!! REBOOT don't help!!! I don't want be a beta tester.
Thanks for all.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
