Give two ranges to a VPN connection
Hi dear,
i've created a new VPN IPSec connection. This connection allow to reach the range 192.168.110.0/24, but i want also allow to reach the range 192.168.100.0/24 with the same VPN connection. Is it possible ? how ?
i've also an another question : SSL VPN connection is working with the Active Directory accounts but with the IPSec VPN connection it is not working with the Active Directory accounts.
Hi steve15f,If site-to-site VPN is created between two Zywalls, you can use policy route to reach the range 192.168.100.0/24 with the same VPN connection.Here is the example.The traffic can be transmitted between the subnet of site A 192.168.1.0/24 and site B 192.168.110.0/24.We want to enable communication between the subnet of site A 192.168.1.0/24 and site B 192.168.100.0/24.So two policy routes we are created:Site A -> source address : 192.168.1.0/24, destination address : 192.168.100.0/24, next-hop : vpn tunnelSite B -> source address : 192.168.100.0/24, destination address : 192.168.1.0/24, next-hop : vpn tunnelIn site-to-site VPN with dynamic peer, the option "Policy Enforcement" is enabled by default, so we can't use policy route to control it.0
@jasailafan, thanks for the instruction.Hi @steve15f,As for IP sec VPN connection is not working with AD, what is the device error log when you connect IPSec VPN client?0
HI @jasailafan thanks for your reply. It's not for a site to site VPN but ZyWALL IPSec VPN (Windows) client .
Hi @steve15f,
You can modify the VPN local policy address mask to /20, mask /20 range is 192.168.96.1 to 192.168.111.254.
In this way, you can add another subnet in one VPN tunnel.
Modify the local policy subnet at “CONFIGURAITON > VPN > IPSec VPN > VPN connection”
Windows IPSec VPN client setting
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
