WAC6503d-s antenna
GDP
How well will the antenna work in buildings with cement walls?
Dear @GDP
You can use our tool to get insides about your question
https://www.zyxel.com/products_services/ZWO-ZyXEL-Wireless-Optimizer/
Hi @GDP
As you know the different materials cause different path loss with the general RF limitation as below screenshot.
However, WAC6503D-S supports 3x3 smart antenna which is suitable for high density scenario / applications. No matter what AP, please make sure your AP is located on the line-of-sight (LoS) view places and it's better where there is no obstacles between AP and your clients.
Please refer to the link with smart antenna in details :
Thanks!
- 6.8K All Categories
- 1.4K Nebula
- 29 Nebula Ideas
- 38 Nebula Status and Incidents
- 3.9K Security
- 200 Security Ideas
- 723 Switch
- 30 Switch Ideas
- 601 WirelessLAN
- 8 WLAN Ideas
- 4.5K Consumer Product
- 98 Service & License
- 214 New and Release
- 38 Security Advisories
- 513 FAQ
- 236 Nebula FAQ
- 117 Security FAQ
- 74 Switch FAQ
- 65 WirelessLAN FAQ
- 5 Consumer Product FAQ
- Documents
- 30 Nebula Monthly Express
- 43 About Community
- 31 Security Highlight
