How to install self-signed ssl cert on USG40
purelight01
Posts: 5 Freshman Member
I need some help on installing ssl cert on the Zyxel USG40.
I run my own local CA and have created new cert and key for my USG40.
The USG40 UI seems to have only option to use USG's own generated certificate.
Is there a way to override this ?
Seems like if this is possible, we have to bypass the ui, perhaps via ssh?
Well, please let me know.
Did you uploaded your cert into USG40 into object/certificates?
5
5 -
Yes I tried but it does not have the option for me to upload my own cert. It creates its own cert. Here is the dialog attached.0
Ok thanks. I am following the instructions now. Will let you know how it goes.0
Worked like a charm! Thanks for the help!0
- 415 Beta Program
- 2.4K Nebula
- 152 Nebula Ideas
- 100 Nebula Status and Incidents
- 5.8K Security
- 287 USG FLEX H Series
- 278 Security Ideas
- 1.5K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 251 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
