Port Role on 310 ..how to?
Phoenix101
On the ZyWall 110 it is easy to group ports in lan1, how to group in ZyWall 310?
I like to put 4 ETHPorts in the same lan?
no Port Role in ZyWall 310 ..how to
Hi @Phoenix101,
ZyWALL 310 doesn't support port group because it has LAG which is able to combine a number of physical ports together. It helps to implement the traffic to perform load balancing or failover features, depending on the scenario of connected switches.
If you'd just like to put 4 ETHPorts in the same lan, simply add a bridge interface with the following interface properties.Then move the selected interfaces to "Member" and configure the IP address and DHCP setting.
Interface type: internal
Interface type: br1
Zone: LAN
It works, Thank you!
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
