Reset of ZyWALL USG series and ATP series.
Hi @Zyxel_Lucious
I'm talking about the RESET switch to put ZyWALL on default setting. I need to disable it, is it possible? Is there a command to do so?
Thank you.
Fernando VieiraBest regards0 -
Hi @dpipro
Since USG and ATP are not switch series.
We've moved this post to Security section and changed the title accordingly.
Zyxel_Lucious0 -
I guess you could void the warranty and de-solder the reset switch.
if your trying to stop someone from pressing the reset put it in a lockable network cabinet.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
