Reset of ZyWALL USG series and ATP series.
dpipro
dpipro Posts: 71  ZCNE Certified
First Comment Friend Collector Sixth Anniversary ZCNE Switch Level 1 Certification - 2020
edited April 2021 in Security
how can I disable the reset switch?
Best regards,
Fernando Vieira
Best regards
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 277  Zyxel Employee
    25 Answers First Comment Friend Collector Seventh Anniversary
    edited October 2019
    Hi @dpipro
    Which model are you using?
    Are you referring the reset button on switch?
    Zyxel_Lucious
  • dpipro
    Hi @Zyxel_Lucious
    I'm talking about the RESET switch to put ZyWALL on default setting. I need to disable it, is it possible? Is there a command to do so?
    Thank you.
    Fernando Vieira
    Best regards
  • Zyxel_Lucious
    Hi @dpipro
    Since USG and ATP are not switch series.
    We've moved this post to Security section and changed the title accordingly.
    Zyxel_Lucious
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,431  Zyxel Employee
    Hi @dpipro,
    There is no command to disable the function of RESET button and it cannot be disabled.
    PeterUK Posts: 3,887  Guru Member
    I guess you could void the warranty and de-solder the reset switch.
    if your trying to stop someone from pressing the reset put it in a lockable network cabinet.
