Port Role on 310 ..how to?
Phoenix101
On the ZyWall 110 it is easy to group ports in lan1, how to group in ZyWall 310?
I like to put 4 ETHPorts in the same lan?
no Port Role in ZyWall 310 ..how to
Hi @Phoenix101,
ZyWALL 310 doesn't support port group because it has LAG which is able to combine a number of physical ports together. It helps to implement the traffic to perform load balancing or failover features, depending on the scenario of connected switches.
If you'd just like to put 4 ETHPorts in the same lan, simply add a bridge interface with the following interface properties.Then move the selected interfaces to "Member" and configure the IP address and DHCP setting.
Interface type: internal
Interface type: br1
Zone: LAN
It works, Thank you!
- 397 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 52 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 63 Security Highlight
