DNS name problem to a server in
alainZerrouk
alainZerrouk Posts: 3 image  Freshman Member
edited April 2021 in Security
all my escuse google translation
routeur USG 110
I would like to give a DNS name to a server on the internal network example my server is reachable with toto.dyndns.org from the outside I would like to be the same in the lan.
Thank you in advance for your response.
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,461 image  Zyxel Employee
    Hi @alainZerrouk,
    Go to CONFIGURATION > System > DNS > Address/PTR Record and add a record for toto.dyndns.org.
    In LAN > DHCP setting, make sure the DNS server is ZyWALL.
  • alainZerrouk
    thank you for your answer it works
