DNS name problem to a server in
alainZerrouk
Thank you in advance for your response.
all my escuse google translation
routeur USG 110
I would like to give a DNS name to a server on the
internal network example my server is reachable with toto.dyndns.org
from the outside I would like to be the same in the lan.Thank you in advance for your response.
Hi @alainZerrouk,
Go to CONFIGURATION > System > DNS > Address/PTR Record and add a record for toto.dyndns.org.
In LAN > DHCP setting, make sure the DNS server is ZyWALL.
thank you for your answer it works
- 595 USG FLEX H Series
- 480 News and Release
