Jason
How to MOVE devices to another site, same organization
I'm in INVENTORY and trying to move a number of devices to ANOTHER SITE, same organization.
I check/select the devices and then go to Add to and select the other site to MOVE them to. Nothing ever changes in the list under the sites the devices are assigned to. When I try to leave the ORGANIZATION an error comes up saying the changes have not been saved but there are no SAVE choices on the screen. What's going on?
How can I MOVE a device from one site to another, SAME ORGANIZATION???
Thanks.
-stew
Thanks.
-stew
Hi @ivessm,
Currently, you may go to each Product category to move device to another site.
The step for Access Point and Switch is:- Go to Access point > Monitor > Access points(Switch > Monitor > Switches)
- Select the devices you want to move.
- Click Move button(Above the device list) and choose the destination site.
- Go to Security gateway > Monitor > Security gateway
- Click Edit button(Beside Configuration)
- Remove gateway from the old site and go to the new site and add again.
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 518 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
