Plex on a zyxel nas326?
Jojjothan
I bought my first NAS to use plex on it but i can't find a good tutorial on it and the text tutorials all have broken links. How do i install it?
And is there a way to have the NAS be displayed as a drive? The regular interface is really clunky and unappealing.
Some talk about docks. What is it and does it make the NAS appear as a drive so i can edit freely?
Rightclick the file, and choose 'Save link as' or equivalent.
For Plex, you can install MetaRepository as described here, scroll down for details. Then you can install a Plex installer script, which allows you to install a Synology Plex package using the webGUI.In Windows you can view the contents of a share by putting \\<nas>\<share> in the address bar of explorer. On Linux (and I think also on macOS) you can use smb://<nas>/<share>0
Mijzelf said:For Plex, you can install MetaRepository as described here, scroll down for details. Then you can install a Plex installer script, which allows you to install a Synology Plex package using the webGUI.In Windows you can view the contents of a share by putting \\<nas>\<share> in the address bar of explorer. On Linux (and I think also on macOS) you can use smb://<nas>/<share>
How do I download web_prefix?0 -
Hello
I followed all the instructions and came until this point; please check the photo on which I show you the steps that I have followed and the problem that I have encountered. Can anybody help me?
I can exactly not read what is on the Plex wrapper page. But when the server is started there should be a button on the bottom which redirects you to the webpage of the Plex server itself.
Mijzelf said:I can exactly not read what is on the Plex wrapper page. But when the server is started there should be a button on the bottom which redirects you to the webpage of the Plex server itself.
Hello @Mijzelf; As I have showed in my previeus enrty, when I clik the Web Interface link of Plex, I receive the 3rd photo (I have put below .
I say "ok" and continue. However it does not scan the files in the directory that I have defined.0 -
Ah, I see. You entered 'Movies2' as directory? In that case the problems is that the internal directory structure is different from the 'external', as in shares you see.Try '/i-data/sysvol/Movies2' (without quotes)0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 917 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 916 Nebula FAQ
- 422 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
