port speed
kolicivu
kolicivu Posts: 3 image  Freshman Member
Hi, the WAN port 1 of a USG60 connect on 100Mbs and not on 1Gbs anymore.
can I change that?
  • CHS
    CHS Posts: 181
    image  Master Member
    edited July 2021 Answer ✓
    In UI, you can change port configuration as 1000Mbps Full Duplex manually.
    In usual it will auto negotiation as 1000M Full by default setting if without any interoperability between 2 devices.
    You can check if your (1) cable (2) WAN side device are support to 1000Mbs.
    The worse case, you can connect a switch between USG and your WAN side device.
  • CHS
    CHS Posts: 181
    image  Master Member
  • kolicivu
    edited December 2021
    thank you.
  • kolicivu
    thank you.
