C3000Z Port Forwarding and Application Forwarding reset after restart
I have a C3000Z with firmware CZD005-4.16.011.0 it is setup to port forward. Trouble is whenever I restart the C3000Z, it erase all the Port Forwarding and Application Forwarding information. It doesn't matter if it is a hard restart from unplugging the model or a soft restart from selecting "reboot" from inside the admin page.
This is a serious flaw.
I also did a test by making a custom application forward
rule, then I set the an IP with the port forwarding rule, then I saved
the configuration file on my desktop.
I rebooted the modem then I saved the configuration file on my desktop.
I opened both files with notepad++ to compare both configuration files and the configuration file after booted has only the custom application forward rule.
I reached out to low lever Century Link support and they think C3000Z modem is bad and I need a new one.
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
