AP management VLAN vs switch settings
Hi TAP Tech,
To set the management VLAN of the AP, simply select an AP in the list of [Access Point > Monitor > Access Points] to enter its detail page. After that, you can see it's management VLAN settings.
By clicking the edit button, you can then configure its management VLAN settings
The LAN1 setting that you see is located in another page [Access Point > Configure > AP&Port settings], which is used to configure other APs that have additional LAN ports, not for the management VLAN of AP itself.
Best Regards,
Richard0
Hi TAP Tech,
Best Regards,
Richard0 -
That's where it is! Thank you so much
- 244 Nebula Ideas
- 6.9K Security
- 797 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 531 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 124 Security Highlight
