VMG8823-B50B connect to wifi for ethernet ports usage
loredin
loredin Posts: 1 image  Freshman Member
edited October 2021 in Smart Home Product
Hello , is that possible to have the model VMG8823-B50B connect to the router of my isp via wifi and grant internet access to its ethernet port ?
Kind Regards
  • tonygibbs16
    tonygibbs16 Posts: 979
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    image  Guru Member
    edited October 2021
    Hello @loredin
    I don't think what you suggest would be a good idea in terms of availability, reliability and security for your connection between your VMG8823-B50B and your ISP router.
    It would be more reliable and more secure for it to be a wired connection.
    This would be an Ethernet WAN connectivity, as shown in the user manual, which can be downloaded from https://manual-hub.com/manuals/zyxel-vmg8825-bx0a-02-pdf-manual/
         - unfortunately, the user guide is not available on the Zyxel website.
    Kind regards,
        Tony
