What license is required for USG/ATP and Plus level?
TAPTech
TAPTech Posts: 174
First Comment Friend Collector Seventh Anniversary Nebula Gratitude
image  Master Member
Is it possible to apply NCC licenses to USG/ATP models that are not Gold?  In some cases we do not needed the advanced security features, but would like to use Plus licenses on the other devices in the network.
  • Zyxel_Jason
    Zyxel_Jason Posts: 432
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    image  Zyxel Employee
    Hi @TAPTech,
    ATP series only supports Gold Security Pack license, so it is not able to register NCC license(Pro/Plus).
    USG FLEX and USG20(W)-VPN series support to register NCC license.
    Hope it helps.
    Jason
  • Zyxel_Jason
    Hi @TAPTech,
    Hope it helps.
    Jason
  • TAPTech
    TAPTech Posts: 174
    image  Master Member
    That clears it up 100%, thank you Jason!  The difference between ATP and USG was confusing me.  Have a nice weekend :)
Nebula Tips & Tricks
