Uplink speed issue NWA210AX and GS1920-24HP
I have tried to reboot both the AP and the switch and even change the port where the AP is connected but nothing happens.
Hi @nsebti
Because the speed is hardware auto-negotiation when AP’s uplink port plug-in, we usually suggest user to swap the switch port / cable with the AP that doesn’t have problem as the simple check method.
According to your description >> change the port where the AP is connected but nothing happens. 2 days ago it randomly worked fine and then the alert came back the next day.
Ensure the cable is tight connected and if the symptom goes alone with the same unit after rule out the switch port and cable issue, please proceed to RMA the AP.
Thank you
Regards,
Bella
Sorry, what do you mean by "RMA the AP"?0
Hi @nsebti
We’d appreciate your result confirmation of above operations, don’t hesitate to share with us and we could check if any further help is available.
For the RMA process, I left a private message to you for getting contact information.
Thank you
Regards,
Bella
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
