NWA50AX remote shutdown and power on
Hi all,
I recently installed a NWA50AX Access point and would like to turn it off at night and wake up in the morning. Is there a way to remotely shutdown it and use wake on lan to start it? I tried the simple way using ssh but it looks like it's not working.
Hi Sir,
Currently we can't directly schedule the AP to reboot itself neither through SSH or NCC configuration.
If you want to stop Wi-Fi services, there're two approaches for your reference:
1. Set the "SSID Schedule", so that AP can broadcast the SSID only on the scheduled time.
(You can refer to the article below for configuration guide)
https://community.zyxel.com/en/discussion/9930/nebula-how-to-configure-ssid-schedule
2. If the AP is powered by a PoE Swtich, there's also a function called "PoE schedule" you can use, so that the Switch will provide electricity to devices on the scheduled period.
(For swtiches managed by Nebula, please refer to this URL for configuration guide)
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=018029&lang=EN
(For switches not managed by Nebula, please refer to the URL below for configuration guide)
https://community.zyxel.com/en/discussion/12213/how-to-configure-poe-schedule-for-zyxel-switch-in-standalone-mode
Best Regards,
Richard
Hi,Thanks mate. I thought about the Poe but my mini zyxel switch is not manageable
They should add a wake on lan function in the AP.And by the way, they say in the doc that you have to use the "poweroff" function of the AP if you want to shut it down (which is probably to avoid potential problems with users)For now, I scheduled the wifi broadcast and will see later for another solution
thanks for your answer.Best,Thibault0
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
