2 WAX510 building Mesh Network
Wolfgang
Wolfgang Posts: 39 image  Freshman Member
Hallo,
i have successfully build a Mesh network with 2 WAX510.
The question is where to see the information in Nebula how they are connected.
Is there an easy way to see this information, which band is used and other stuff?
Thx
Wolfgang
  • Zyxel_HsinBo
    Zyxel_HsinBo Posts: 525 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
    edited May 2022 Answer ✓
    Hi, @Wolfgang
    Thanks for consulting Nebula support!
    According to your description,
    If you have our Pro-pack license, you can see the topology of your network from the below path, which includes how the root AP and the repeater AP connect together.
    PATH: Site-wide >> Monitor >> topology
    If you are a base pack user, you may not see the topology but you can still check your root AP and repeater AP info from the path below
    PATH: Access point >> Monitor >> Access point
    Root AP (Green Solid icon)
    Repeater AP (Green Hollow icon)
    There would be AP information for your requirement from the path (Access point >> Monitor >> Access point), you can see more detailed information by clicking the AP from the AP list.
    Hope the answer would solve your problem.
    Have a nice day, Thank you!
    Best Regards,
    HsinBo
  • Zyxel_HsinBo
    Hi, @Wolfgang
    Best Regards,
    HsinBo
Nebula Tips & Tricks
