because I have lost connection with usg flex 200?
Tecnoprogramm
in Security
for a week during the work I have continuous connection losses. The firewall has always been fine (it has been running for 3 months) but it has been creating these problems for a few days.
I did some tests: if I work with the single WAN (wan 1 or Wan 2) disconnecting or one or the other I work regularly. instead I tried to disable the Wan 2 from CLI but the problem still exists.
the firmware is up to date
Hi @Tecnoprogramm
Just some questions to understand your configuration..
Are you referring to lan-to-wan traffic?
Are you using a wan trunk?
Do you see something inside logs?
Fred0 -
hi Fredyes there is a trunk.this morning everything seems to be working.yesterday the only thing I did is update firmware and change some parameters on the WAN2 router.I will keep you updated if I receive reportsthank you0
Tecnoprogramm
May we know if this problem still exists? Is there any error Monitor log message generated? Not sure if this problem is related to ISP or network , maybe you can use a PC continuously to ping 8.8.8.8 with timestamp(you can enter the CLI with system administrator role in the PC "ping -t 8.8.8.8|cmd /q /v /c "(pause&pause)>nul & for /l %a in () do (set /p "data=" && echo(!date! !time! !data!)&ping -n 2 8.8.8.8>nul" >C:\PingResult.txt") then save the ping result and see if there are any drop clues on the ping result. It may be easy to know when you lost the connection.0
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
