Mesh / Roaming possible between multiple NWA90AX APs without using Nebula?
maw
maw Posts: 1 image  Freshman Member
edited May 2024 in Wireless
is it somehow possible to use Mesh / Roaming between multiple NWA APs (to make video/audio calls without interrupts when moving between APs) when using  the standalone mode?
Thanks for your feedback!
  • Zyxel_Bella
    Zyxel_Bella Posts: 620
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    image  Zyxel Employee
    Hi @maw
    Welcome to Zyxel community!
    For seamless roaming between wireless network deployment in standalone mode, you have to setup same SSID profile with same password on two APs.
    The best practice is to ensure 15 to 20% signal coverage overlap between APs, for signal survey, you could use the scan tool such as inSSIDer for laptop to check when walking from one AP to another. Most clients start roaming when signal drops to -65 to -75dBm so we suggest the coverage area should at least around -65dBm.
    Thank you
    Regards,
    Bella
