WiFi versus Wireless LANs
olansgzsid
olansgzsid Posts: 2
image  Freshman Member
edited May 2024 in Wireless
I've just started learning about Wireless networks and i have a question about the terms "Wifi" and "wirless Lan"
Whenever I think of WiFi, I think of connecting wirelessly to the network and to the internet, which is basically what a WLAN is, right?
Can these 2 terms be used interchangeably or is there any major difference between a WiFi and a Wireless LAN?
  • Zyxel_Jay
    Zyxel_Jay Posts: 226
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 5 Answers
    image  Zyxel Employee
    edited December 2022 Answer ✓
    In general, "WiFi" and "wireless LAN" refer to the same concept: the transmission of data over a wireless connection using radio waves. However, when "WiFi" is used more specifically, it refers to a specific protocol, such as WiFi 1 through 6, which involves the development of products that adhere to a set of agreed-upon standards. These products are designed to be compatible with the WiFi protocol and allow users to connect to the internet wirelessly.
    Jay
  • Zyxel_Jay
    Jay
  • olansgzsid
    olansgzsid Posts: 2
    Jay
    Thanks for precious response... Appreciated your efforts...!!!
