Nas542 Network problem
bulutnet
Hello. I bought Zyxel Nas542. latest software version after using for a while V5.21(ABAG.9) I upgraded. I can't get pppoe connection after upgrade. It does not accept the process of reverting to the old version. I'm waiting for your help.
If you login over ssh (as root) and execute
echo 1 > /firmware/mnt/info/revision
you can downgrade by uploading a firmware file in the webinterface.
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
