Zyxel USG Flex 100 no connection to wan and lan
Hi @BLS_Philippines ,
Greeting Forum, Did you have serial console cable ?
Please kindly share your output. or we can have remote session to check this issue.
Thank you
Are you pressing the reset in as the USG is on?
Yes it is on.
Thanks your reply, We need to clarify the current status of the device through the console.
We can have remote session to assist you. Thank you
Zyxel_KevinPosts:353Master MemberApril 11Hi@BLS_Philippines,Thanks your reply, We need to clarify the current status of the device through the console.We can have remote session to assist you. Thank youSir Kevin the problem is I cannot connect to the Zyxel firewall via LAN
Let me provide first the console cable. Thank you.
- 244 Nebula Ideas
- 6.9K Security
- 798 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 531 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 124 Security Highlight
