Problems in Logfile of NWA50AX
what does this mean and is this explaining connection problems like "wrong password" (whereas the PW is definitely correct) ?
Station+++: disconnected by STA timeout on Channel: 36, SSID: +++, 5GHz, Signal: -81dBm, Download/Upload: 751191/207752 Bytes, reason 107, Interface: wlan-2-12023-05-08 13:11:07++++ LANStation: ++++ blocked by key handshake fail on Channel: 36, SSID: +++, 5GHz, Signal: -47dBm, Download/Upload: 452/0 Bytes, reason 2, Interface: wlan-2-1
Hi @TheMichaelOne
The “wrong password” event may be caused by the “blocked by key handshake fail” log.
Regarding to 'blocked by key handshake fail' log, it means the authentication process is uncompleted. As the normal, it will happen in cases:- Poor signal quality
Solution: Fine-tune the deployment of AP's location. The client connects signal recommended –70dBm or above - Incorrect password
Solution: Verify that the password is correct - Network channel interference
Solution: Let AP radios have a better channel- Enable DCS schedule
- Disable "DCS client aware" to let the AP jump to the better channel when there are connectedclients.
- Disable "Avoid 5G DFS channel" to let the AP have more options.
If the above solutions do not resolve your problem, please collect the diagnostic file for further assistance. You may download the diag. file from the AP local GUI > Maintenance > Diagnostics > Diagnostics. After downloading the diag. file, please send it to us along with the MAC address of the client that experienced the problem via private message. Remember to zip the file before sending it.
Alternatively, if your AP is on Nebula Cloud mode, please enable Zyxel Support at NCC >> Help >> Support request and provide us with your org/site name.
Kay
Kay
0 - Poor signal quality
Thank you so far, I tried the settings and activated administrative access for you as advised.
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
