NWA50AX nebula without licence ?
Hi @My_ZyxLan
For the Base Pack Nebula, you may configure your SSID settings, enable the smart mesh function, configure the radio settings and monitor your access points online, these functions are free of charge.
However, if you require additional features and support provided by the Plus and Pro Pack subscriptions, there are associated costs. To explore the benefits of these packs, please refer to the following link:
Nebula Control Center - Subscribe Nebula | Zyxel NetworksRelated to roaming, it is the behavior of clients handle with the difference AP. To achieve the roaming function with your two NWA50AX access points, you can set:
- The same SSID and security method
- 15% to 20% overlapping coverage for 2 APs
You can also enable 802.11 k/v/r to assist roaming and support fast roaming (Configure > Access point > SSID advanced setting).
Kay
Kay
Hi @My_ZyxLan
Kay
Kay
- 236 Nebula Ideas
- 6.8K Security
- 739 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
