Virtual LAN interface in Nebula ATP200
Hi @AHGJSoree
Thanks for your inquiry. Currently, the nebula doesn't support the virtual interface feature. We will shift your post to Nebula ideas for further evaluation. Thanks.
Hi @AHGJSoree
We already created an idea discussion for you, thanks.
Hi @AHGJSoree
Could you please explain why you intend to configure a virtual interface on the LAN interface? Is there a specific purpose or goal you have in mind? Thank you.
We are currently changing our subnet from 192.168.220.0/24 to 172.16.127.0/24. We are using an old USG310 still so adding an extra IP address as a gateway is an easy way. The USG310 then acts as a default gateway with both subnets. This is an easy quick approach.
Jeroen
Hi @AHGJSoree
OK, thanks for your update for us.
- 244 Nebula Ideas
- 6.9K Security
- 801 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
