[ATP/FLEX] Why I cannot add port1 to LAN1 or LAN2 Group in Port Group?
Zyxel_James
Question: Why I cannot add port1 to LAN1 or LAN2 Group?
Answer:
Port1 is the SFP which cannot be in the same LAN group as ethernet ports. Meanwhile, ethernet port 3,4,5 are in LAN1 group, so por1(SFP port) cannot be added into LAN1 group
Solution:
You may click +Add to create a new LAN group for the SFP port, or you can move the ethernet ports from LAN1 group to the new created LAN group, then you can add SFP port to LAN1 group.
- 588 USG FLEX H Series
- 477 News and Release
