EX3301 T0 Port Forwarding issue
gilbobs
gilbobs image  Freshman Member
Hi, I'm a newb to the EX3301 T0 Router, in the past, I've simply used an external domain and pointed it at the router and forwarded the necessary ports. Following the same logic the ports appear not to be forwarded although the domain is pointing at the router. I suspect there are additional rules that need setting up, and advise or pointers or tutorials would be appreciated….. thanks
  • HouliCrab
    HouliCrab image  Freshman Member
    First Answer First Comment Friend Collector Sixth Anniversary
    I think you need port forwarding function, it has in the device.
