DX3301-T0 Wifi connection
Jobr
in Home Router
When I use/ check “Keep the same settings for 2.4G and 5G wireless networks” everything work fine, wifi6 is indicated on upper right corner on devices, connection is fast and stable. Until OS will internaly detecting wifi connection in case of large data downloads or updates.
Then in these cases I am asked, if it need to wait for wifi connection or start immediatelly and iOS upgrade is disabled till Inwillmconnect to wifi, even that wifi connection is still indicated on upper right corner :-(
So I have to split again 2,4 and 5 gig into separate wifis, upgrade OS and beck again
Any suggestion where could be a problem?
I recommend that you request new firmware from your ISP or retailer and then try again.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
