A comprehensive guide of replacing devices in Nebula
This article is designed to walk you through the process of replacing a device within Nebula. It will provide a step-by-step guide for device replacement, outline which configurations require reconfiguration, and identify configurations that can remain unchanged after successfully swapping your device due to an RMA or exchange.
Firewall
Note: The following table applies when changing your firewall to the same model (e.g., USG FLEX 500 to USG FLEX 500) and not when transitioning to a new model (e.g., USG FLEX 500 to ATP200).
Section
Configuration
Needs re-config
Site-wide > Devices > Firewall
Firewall Name
Yes
Site-wide > Configure > Firewall > Port
Port Group
No
Site-wide > Configure > Firewall > Interface
WAN interface, LAN/VLAN interface
No
Site-wide > Configure > Firewall > Routing
Policy Route/Traffic Shaping, Static Route, WAN load balancing
No
Site-wide > Configure > Firewall > NAT
Virtual Server, 1:1 NAT
No
Site-wide > Configure > Firewall > Site-to-Site VPN
Site-to-Site VPN, Non-Nebula VPN peers
No
Site-wide > Configure > Firewall > Remote VPN
Domain name, IPSec VPN Server, L2TP over IPSec
No
Site-wide > Configure > Firewall > Security Policy
Security Policy, Anomaly Detection and Prevention, Session Control
No
Site-wide > Configure > Firewall > Security Service
Content Filter, Application Patrol, DNS/URL Threat Filter, IP Reputation, Sandboxing, Intrusion Prevention System (IPS)
No
Site-wide > Configure > Firewall > Captive Portal
Captive Portal
No
Site-wide > Configure > Firewall > Authentication Method
Network Access
No
Site-wide > Configure > Firewall > Firewall Settings
DNS, Dynamic DNS, Authentication Server, Wallet Garden
No
Switch
Section
Configuration
Needs re-config
Site-Wide > Monitor > Switch > "Switch Name"
Configuration (Switch Name), Status (IP Configuration, DNS Configuration
Yes
Site-Wide > Devices > Switches > Switch Name > Port X
Port Name, Tags, Port enable, RSTP, STP Guard, LLDP, Link Port isolation, IPSG Protected, Bandwidth Control, Loop guard, Storm Control, Type, Management Control, PVID, Allowed VLANs, IPTV Settings
Yes
Site-wide > Configure > Switches > ACL
Management Rules, Customization Rules
No
Site-wide > Configure > Switches > IP & Routing
IP Interface, Static Route
No
Site-wide > Configure > Switches > ONVIF Discovery
ONVIF Configuration
No
Site-wide > Configure > Switches > Advanced IGMP
IGMP Configuration
No
Site-wide > Configure > Switches > Authentication
Authentication Server, Authentication Policy
No
Site-wide > Configure > Switches > PoE Schedules
PoE Schedule
No
Site-wide > Configure > Switches > Switch Settings
Auto-configuration recovery, VLAN configuration (Management VLAN only), STP Configuration, Quality of Service, Voice VLAN etc.
No
Access Point
Section
Configuration
Needs re-config
Site-Wide > Monitor > Access Points > AP Name
Configuration (AP Name), Status (IP Configuration, DNS Configuration
Yes
Site-wide > Configure > WiFi SSID Settings
WiFi Name, WiFi Settings, Guest Network
No
Site-wide > Configure > Access Points > SSID Advanced Settings
Network Access, Traffic Options, Advanced Settings
No
Site-wide > Configure > Access Points > Captive Portal Customization
Themes, Click-to-continue/Voucher/sign-on page, External Captive Portal URL, Captive Portal Behavior
No
Site-wide > Configure > Access Points > SSID Availability
SSID Availability, SSID Schedule
No
Site-wide > Configure > Access Points > Radio Settings
Country, Maximum Output Power, Channel width, DCS setting, Smart Steering, WLAN Rate Control
No
Site-wide > Configure > Access Points > Radio Settings > Edit (AP List - 2,4/5/6GHz Radios)
Radio mode, Channel, Channel Width, Maximum Output power, Airtime Fairness, Smart Steering (all parameters per AP)
Yes
Site-wide > Configure > Access Points > Traffic Shaping
WLAN Traffic Shaping
No
Site-wide > Configure > Access Points > Security Service
Application Visibility & Optimization, Threat Protection
No
Site-wide > Configure > Access Points > AP Port Settings
General Setting, Load Balancing, Port Setting
No
Site-wide > Configure > Access Points > AP Port Settings > Edit (AP List)
Enabled, PVID, Allowed VLANs
Yes
Save Configuration via Configuration Management
Configuration synchronization allows you to easily copy configurations from one site or Nebula Device to another. Use this screen to synchronize the configuration between sites or switch ports. You can also back up the current configurations for sites or switches to the NCC and restore the configuration at a later date.
You may clone a site configuration to a new site or clone a particular switch configuration to another switch in the same site via the Backup & Restore section of the "Configuration management" settings.
Replace/Swap a Device in Nebula
Note: Before proceeding with the device exchange, ensure you have the necessary owner privileges to perform actions within the NCC.
Navigate to Organization-wide > Administrators
Step 1: Remove the Old Device from the Organization
  • Navigate to Organization-wide > License & inventory > Devices
  • Locate the old device that you wish to swap and mark it
  • Click on "Actions" and then choose "Remove from Organization"
  • Confirm the action by clicking "Yes" when prompted
Step 3: Add the New Device to the Organization
  • Click on the "Add Device" button
  • Enter the serial number and MAC address of the new device, or scan the QR code using the Nebula mobile application
  • Follow the on-screen instructions to complete the device registration process
Step 4: Assign the New Device to the Organization
  • Once the new device is successfully added, go to the "Devices" list under "License & Inventory"
  • Locate the newly added device and ensure it is selected
  • Click on "Actions" and choose "Assign to Organization"
  • Select the same organization that the old device was assigned to
Step 5: Configure the Device Deployment Method
If you have a firewall in your network, you need to choose the appropriate deployment method for the new Zyxel device.
Nebula Native Mode (Recommended):
  • Navigate to "Organization-wide" and select "Network-wide Settings"
  • Click on "Deployment Method" and choose "Nebula Native Mode"
  • Save the settings to apply Nebula Native Mode to the new device.
ZTP Mode (if Nebula Native Mode is not available):
  • Connect a PC locally to Port 4 (P4) and your WAN connection to Port 2 (P2) of the new device.
  • Log in to Nebula Cloud Center and go to "Site-wide" select "Monitor" and then "Devices"
  • Locate the new device and click on "Firewall" settings.
  • Select "ZTP Process" and follow the provided instructions to complete the ZTP configuration.
Step 6: Verify Device Online Status
  • Allow some time for the new device to come online (maximum 5 minutes) and establish a connection to Nebula
  • Cloud Center. Check the device's online status in the "Devices" section to ensure it is functioning correctly.
Congratulations! You have successfully exchanged a Zyxel device in Nebula Cloud Center, and the new device is now fully operational within your organization's network.
Kay
