How to disable DHCP settings and set the LAN2 port as a locally managed port?
Scenario :
This article will guide you on how to disable DHCP settings and set the LAN port as a locally managed port for better security for you.
Answer :
For example, if the user wants to restrict administrator access to only lan2 for firewall management, they should navigate to Configuration > Networks > Interface > Ethernet > lan2 and configure the IP address as 192.168.2.1 with DHCP set to None.
Kindly Reminder :
Since lan2 does not have a DHCP server setting, the PC needs to be configured with a static IP address in the same domain as the lan2 interface's IP, such as 192.168.2.88. Afterward, you can connect to the lan2 port using a web browser and enter the URL https://192.168.2.1 to access the local Web-GUI page. Besides, please ensure the security policy from LAN2 to Zywall can be allowed by the security policy.
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
