WBE660S Wi-Fi 7 AP power supply and behavior
Zyxel_Judy
Zyxel_Judy Posts: 2,851
image  Zyxel Employee
edited November 2023 in AP & Port setting
WBE660S requires an input through a USB Type C connection. To meet this AP’s specification, the power supply should reach at least 45 watts. For example, each port should have a 15V3A capability.
If powered by USB-C, while the power supply is insufficient, the AP will not power on, meanwhile the small LED light next to the power socket will light up in red, indicating that it is powered but the power is not enough.
AP will take USB-C prior to PoE as power source. So, if AP connect to and USB-C adapter with insufficient power supply, and also connects to a PoE Switch providing 802.3bt power, AP will remain power off status.
To know more about the WBE660S specification, please refer to this link.
Zyxel_Judy
