Upgrade Firmware LTE5398-M904, not band 1 work
Magicszi
Hi, I updated the modem to version 12 of the LTE module (released by you). It no longer aggregates band 1 with the other bands, nor does it use only band 1 to navigate. I would like to downgrade to version 8, the one previously installed. Can you carry out the procedure remotely? Or can you possibly pass me the file to update manually? I can no longer work with this modem, I tried to reset but the problem persists. Model: LTE5398-M904 Installed version: EG18EAPAR01A12M4G Previously installed version: EG18EAPAR01A08M4G
Have you tried find local support?
Where did you purchase the device?
Same problem with band 1 after upgrade, i'm search file to downgrade at EG18EAPAR01A08M4G
Did you purchase it from ISP? Or where did you purchse ?
To upgrade or downgrade FW, it might need the support from the local survice.
Same Problem here after upgrade to EG18EAPAR01A12M4G.
No more connecting to Band 1.
Band 3, 8 und 20 works, also in CA up to 150MBit/60MBit down/up.0 -
also no band 1 with EG18EAPAR01A13M4G
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
