Flex 500 Full Tunel SSLVPN with 2FA Authorization Problem
Peter_EO
Peter_EO Posts: 4
image  Freshman Member
We have set up SSLVPN + Windows AD + Two-FA (Email) on Flex500. The setup has been completed and tested successfully. However, the client has another requirement, which is to use SSLVPN Full Tunnel. But this creates a contradictory situation:
When the user authenticates with the Windows AD username and password and obtains the IP distributed by SSLVPN, Flex500 sends an AUTHORIZE email to the user. But because SSL Full Tunnel Mode is enabled, all traffic is directed to Flex 500. However, this traffic has not yet been authorized, which prevents the user from connecting to the Internet and the company’s Mail Server to receive emails, resulting in SSLVPN being unable to connect.
How should this issue be solve ?
Best Answers
  • zyman2008
    zyman2008 Posts: 248
    50 Answers First Comment Friend Collector Ninth Anniversary
    image  Master Member
    edited December 2023 Answer ✓
    Hi @Peter_EO,
    Yes, it's a Chicken or the egg situation.
    You need another client device (ex: mobile phone) to get the token in the email.
    Impossible with the VPN client device only.
    Or you need to use Google Authenticator or SMS to get token instead of email.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,408
    100 Answers 500 Comments Friend Collector Sixth Anniversary
    image  Zyxel Employee
    Helllo @Peter_EO
    You could refer to this FAQ : How to Use Two Factor with Google Authenticator for VPN Access? If you build VPN tunnel by SSL VPN or L2TP VPN, you have to enter the correct URL to enter the verification code. Thanks.
  • Zyxel_Jeff
    Hi @Peter_EO
    "We have set up SSLVPN + Windows AD + Two-FA (Email) on Flex500. The setup has been completed and tested successfully." When establishing an SSL VPN connection, did you enable Full Tunnel mode? Could you share screenshots of both successful and failed SSL VPN settings with us? We would like to know your settings. Thanks.
  • zyman2008
    image  Master Member
    Hi @Peter_EO,
  • Zyxel_Jeff
    Helllo @Peter_EO
