What's the difference between Nebula Plus and Pro pack license?
Zyxel_Ivan
Zyxel_Ivan Posts: 410
Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
image  Zyxel Employee
The Nebula provides the same free service as the Base pack, and if you need further functions to help you manage your devices through Nebula, you can consider purchasing the Plus or Pro pack license.
The difference between three packs, please follow our web site for the latest information:
https://www.zyxel.com/global/en/products/management-and-reporting/cloud-networking-management-nebula-control-center/subscribe-nebula
If you need the Nebula licenses, you can purchase them from the NCC Portal.
